PCI card
boots
PCI card
Post by boots » Fri 12 Sep , 2008 20:06 pm
Miromill 2000 with a Denstep card.
The new computers only have USB ports.
Is it possible to install a PCI card with a serial port into the computer so that the computer can use the serial cable to connect to the machine?
Post by Steve » Mon 22 Sep , 2008 8:27 am
Yes its as easy as that :D
Post by Denford Admin » Mon 22 Sep , 2008 8:51 am
I would also recommend you use a PCI RS232 card rather than a USB type one.
The USB adaptors don't seem to act like genuine RS232 hardware, and cause lots of communication issues with the machines.
Lone_Ranger
Post by Lone_Ranger » Mon 22 Sep , 2008 10:07 am
I just went and bought a Serial to USB cable adapter set, cost from local computer shop was £9.99 and comes with a CD with the right drivers etc, I now have a 25 pin connector at the machine and a USB 2 into the Laptop!!
I use the cable on a Denford Cyclone Lathe 1990 vintage with no problems at all.
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Post by Denford Admin » Mon 22 Sep , 2008 11:15 am
They seem to work ok at lower baudrates (eg 9600) but we have had no end of problems with the more recent controls which ran at 57600 baud.
I would also recommend spending a little bit more on a quality brand, whichever type you go for - there is a difference - if it means your machine runs without intermittent problems, then its worth the few extra dollars.
Lone_Ranger
Post by Lone_Ranger » Mon 22 Sep , 2008 16:35 pm
To be fair I am only running at 4800 baud rate, lathe, so the programs aren`t very big so not an issue for me!!
Post by Steve » Wed 24 Sep , 2008 10:47 am
You are far better doing what you suggested orrigionally! Install a PCI card with a serial port. USB Serial port replicators do not always work :!:
