microrouter 4 ns not connecting to the computer
Posted: Wed 15 Jun , 2016 18:22 pm
by papa_dogo
the computer is not finding the microrouter. the error message says to check that the machine is on (it is) and check the rs232 cable (the rs232 cable seems fine).
i opened the control panel and the control card flashes 8. d3 and d4 are flashing at the same rate.
(leading up to this problem, i was getting 'transmit buffer is full' errors.
Re: microrouter 4 ns not connecting to the computer
Posted: Thu 16 Jun , 2016 8:11 am
It sounds like the RS232 cable may be faulty.
Posted: Thu 16 Jun , 2016 14:47 pm
by papa_dogo
switched the rs232 cable and it started working!
however, there is an issue where it sometimes loses the z coordinate zero and plunges down until e-stop is hit. suggestions?
Posted: Fri 17 Jun , 2016 6:34 am
Does it plunge when you home the machine or is it during a program?
Posted: Wed 21 Sep , 2016 18:44 pm
by papa_dogo
sorry for the long time between posts. school was on summer break. it plunges during the program.
Posted: Wed 30 Nov , 2016 15:44 pm
by papa_dogo
inspector x from denford solved this for me. the winding nut was causing resistance. and making the z axis lose zero. proper cleaning silicone lube fixed it.
