2001 Microrouter X-axis problem
Posted: Fri 17 Oct , 2008 19:36 pm
Microrouter Oct. 2001
VR Milling v2
We are having problems with the X-axis on the Microrouter. When the machine is jogged the X-axis moves very smoothly, but when running a file the X-axis stutters and moves very roughly, like it is jammed or stalling. The machine has always worked smoothly, this is a recent problem.
We have checked that the X-axis carriages are square/parallel, the belt is snug, the pulleys are tight on the lead screw shafts, the machine is clean and we only use spray dry silicone for lube.
Any ideas on how to solve this problem.
VR Milling v2
