Which MicroMill 2000 Wiring Diagrams?
Posted: Thu 08 Nov , 2012 21:43 pm
by 762x51
I cannot find a set of wiring diagrams that match the MicroMill 2000 I have.
Would someone point me in the right direction......
Thanks in advance,
Orin
Here are photos of the data plate, electronics panel, and close-ups of the 5 relays and controller.
Speed controller appears to be a KB Electronics.
Re: Which MicroMill 2000 Wiring Diagrams?
Posted: Tue 13 Nov , 2012 16:07 pm
by 762x51
Are the attached drawings the ones I should use for my MicroMill 2000?
It appears that collectively they would be correct for my machine.
These drawings are from file MicroTurn-Electrical-Denstep-110v-circa2000.pdf which I found at:
viewtopic.php?f=36&t=2929
Based on other Denford drawing sets numbering sequence I've looked at, the drawings missing are MK2-1, MK2-2, and MK2-4
and drawings MT-2000-1, MT-2000-2, and MT-2000-4 could be used to replace the missing drawings.
Orin
Posted: Tue 13 Nov , 2012 17:47 pm
by Steve
Use the Micromill 2000 Denstep drawings from the attached link:
Posted: Tue 13 Nov , 2012 18:59 pm
by 762x51
Steve wrote:Use the Micromill 2000 Denstep drawings from the attached link:
Please take a look at the photos of the electronics panel in my MicroMill 2000.
Note that there are 5 relays, not 3 as in the drawings you recommended and that the spindle speed is controlled from the DenStep and not from the front panel mounted pot.
Posted: Wed 14 Nov , 2012 10:39 am
Sorry but I can't find any drawings which match your machine...it could be a development or test machine which would have been documented in the USA office (now closed)
I've added all I could find to this post:
Posted: Wed 14 Nov , 2012 14:13 pm
by 762x51
Thank you very much for posting the drawings.
The drawing series M2K-AU xx in file Micromill-2000-denstep-110v-1.pdf appears at first glance to be correct for my machine.
Orin
