There is an arc that cuts 90 degrees from the center out to about 1/2" diameter in a clockwise direction.
When the machine trys to make the finishing cut it moves 270 degrees in a counter clockwise direction.
If it did not crash it woud then cut the part correctly.
I am sure I have to change a setting in a post file somewhere but cannot remember which one.
I was using the Mictoturn Imperial Post.
Please can you advise where the file is located and what needs to be changed.
