Motor and spindle pulley
Posted: Tue 10 Apr , 2018 20:00 pm
by nemo1966
Hi I have an Easiturn 3 - the motor pulley is 52.4mm (50mm nom ?) and the spindle pulley is 63.50mm (60mm nom?) - both are V belt with 10 grooves.
The motor pulley has a 24mm ID hole in it with keyway
I would like to change the motor pulley to the same size as the spindle pulley (so I get a 1:1 ratio).
Does anyone jkow where I can get a 10 groove pulley from?
thanks
Re: Motor and spindle pulley
Posted: Tue 10 Apr , 2018 22:18 pm
by TDIPower
Have you tried Simply Bearings? they do more than that, I've had belts and pulleys in the past.
Posted: Tue 10 Apr , 2018 23:36 pm
by nemo1966
TDIPower wrote:Have you tried Simply Bearings? they do more than that, I've had belts and pulleys in the past.
First place I looked. I can find 8 groove and 12 but not 10.
thanks
Posted: Wed 11 Apr , 2018 18:48 pm
by TDIPower
If the 12 fits I would run that but on 10 grooves
You will need a belt also.
I've been looking at my starturn 5, it has a step down on the drive ratio also, so I have a motor with max speed of 4000rpm and a chuck max or 1800rpm. I did wonder about changing the drive pulley to 1:1 but not sure about the loss of grunt. Also haven't found a supplier of the correct drive belts yet (either original size or what would be required.)
Posted: Fri 11 May , 2018 8:47 am
by ClitheroeKate
I have a rusty 50mm pulley if its any use. 10 grooves, 24mm ish bore, key way.
It was taken from an Easyturn motor, 2hp.
