Hi all. i ve only just sorted the problem i had with my sd 20 drives and now have another problem. The keyboard does nt work. i ve disconnected it an plugged it in again to see if it was a dodgy connection but had no luck. Has anybody got any ideas.
Easiturn Keyboard
- Triac whizz
hmmm, seems unlikely but if you thump those old keys too hard it breaks the magnetic glass encapsuled magic bit. Other than that I'm as lost as you.
but it's probably going to be a retro fit when you do make it go as the control is absolute rubbish compared to what we expect these days.
www.la-coterie.com
www.la-coterie.com
thanks for the reply. what retro fit would you suggest an how much is it likely to cost. i just seem to be getting one problem after another trying to run it as it is. The machine itself seems solid an very accurate for its age but the electonics keep letting it down and unfortunatly i am not to good with electrics
cheers
steve
cheers
steve
