Cyclone Turret problem
Posted: Sun 06 Mar , 2011 9:41 am
Usual scenario, just at the end of an urgent job, for new client !
Problem is: Turret will not rotate under CNC control or manually using the station selection knob and button on the front of the machine. Everything else works on the machine, spindle, axis home etc. Turret is 6 station Barrifuldi, (spelling ! )
If selecting a position manually, you can hear one contactor going in, but nothing happens. Looking in the back of the machine it is the contactor marked TPFC that operates. If I depress the contacts on TPRC maually, while TPFC is still in, the turret will come out from its locked position, but wont rotate. Stangely enough, when this problem happened yesterday, doing this was enough to get it all working again.
We do often get alarms saying Turret overheat, but all thats required is a quick "Twiddle" with the cable plug located at the top of the Z axis, from the 6 station Barrifaldi, to cure this, so we put this down to a poor contact in the plugs socket. Lathe can run for a considerable time before it re occurs.
Another question is, how on earth does that plug come apart? Its an RS plug with multi pins that connects the turret to the machine, we wonder if there is a broken wire in there.
Final thing that is bugging me, is a row of red lights on the PCB card on the machines back panel, the bit that opens and lays down. Panel would be top left if standing in front of the lathe with the back in its closed position. There was one alarm during our attempts to get this running, which said something like power supply, and I wonder if all these red lights are related to my issue.
Bob
Bob
