Cyclone Turret overheat alarm 1007
Emimec
Post by Emimec » Sat 07 Mar , 2009 15:29 pm
I keep getting alarm
1007 turret overheat alarm.
Any ideas how to cure this please, the turret doesnt even feel warm !!!
Bob
Lone_Ranger
Re: Cyclone Turret overheat alarm 1007
Post by Lone_Ranger » Sat 07 Mar , 2009 21:59 pm
Emimec wrote:I keep getting alarm
Bob
Bob
Doesn`t have to mean the actual turret itself has an "overheat" problem, could easlily be on the control card or even the transformer!
Or it could even be similar to the issue you had with the spindle drive "overheat" issue which turned out to be no 24V control voltage, maybe worth checking the supply to the Turret control unit??
Rob
Post by Martin » Sun 08 Mar , 2009 12:28 pm
Check that the Barruffaldi control card is seated fully(if it has one fitted). It will be in the box on the back of the machine & is a card with terminals down either side with a board slotted in to a plug down the centre. This card has a load of LED`s on it. It may be loose & not fully seated. You can fasten large tyewraps around to secure it.
Emimec
Post by Emimec » Sun 08 Mar , 2009 18:39 pm
Many thanks
I will have a look for this card and check it out.
I will ask Badders if it is possible to find the electrical drawings and schematic for my machine, and carry electrical checks along the line.
Bob
Lone_Ranger
Post by Lone_Ranger » Sun 08 Mar , 2009 23:31 pm
Emimec wrote:Many thanks
Bob
If your layout is the same as mine then the turret control card is located on the door at the right hand end looking at the control box from the back of the machine. So when you drop the door down the card should be upright.
Rob
Emimec
Post by Emimec » Mon 09 Mar , 2009 7:55 am
Hi Rob
Yes, thats the same as mine, and it does have plastic ties round it to hold it in. I will double check the seating of this.
Bob
