I have drawn a 20mm x 20mm square using techsoft 2D design and cut it out using a 2.5mm diameter cutter. I got a 22.5 x 22.5mm square as expected. However, when I used the tool offset when I came to the plot option and pen settings plot I put in 1.25 and then -1.25 nothing changed. I still got a 22.5mm square.
So, two questions here :
1) How do I get a 20mm milled square pocket with a 2.5mm diameter cutter, make the vector line 17.5mm square ?
2) What is the tool offset for in the plot menu pen set up ??
Any help appreciated
