I've been experimenting with internal machining on a Mirac and have produced the attached .LCM file.
When I try to generate Gcode I get the errors below which I do not understand.
(Drilling)
Cannot Process: Drill:8 diam:6.00 is less than current internal diam:11.11
Cannot Process: Drill:4 diam:10.00 is less than current internal diam:11.11
(Internal Roughing)
Cannot Process: Current internal diam:11.11 is less than min. tool diam:12.00
There is no internal diameter of 11.11mm and I don't see how it matters in any case when drilling.
I can understand the Internal Roughing problem as the boring tool is specified as 12mm and in order to start boring it would need to make a cut of 1mm in order to enter a 10mm drilled hole and that's with zero clearance on the back edge of the tool. There's still a reference to an internal diameter of 11.11mm though.
Would appreciate any advice. Thanks, Max.
EDIT. Can't upload .lcm file so renamed as .txt
Internal machining. Error messages.
- internal.txt
- (99.22 KiB) Downloaded 122 times
Re: Internal machining. Error messages.
Hi Max,
it looks like it must be related to some settings you have made within Quickturn2D Design. i have opened and simulated your drawing without errors on a standard installation of QuickTurn. i suggest you make a fresh install of the software.
did the machine manage to complete the centre drill operation?
Thanks for the explanation.
The problem is down to my defining a centre drill as having a major diameter of 7/16", 0.4375" or 11.113mm.
This looks perfectly legitimate to me. QT2DD seems to be working on the major diameter rather than the minor diameter, hence the error.
MAX
MAX
- Mirac Tooling.jpg (62.02 KiB) Viewed 1732 times
I managed to get rid of the drilling errors by fitting a 6mm centre drill in place of the 11.1mm diameter one fitted and editing the tooling file accordingly. I believe Miracs came with 5mm centre drills? I had use a 6mm one as the only spare DB25 holders I have for use with my ATC have 6mm bores.
The error relating to needing a minimum tool diameter of 12mm seems to be explained in this thread:-
https://www.denfordata.com/bb/viewtopic ... ter#p25125
This suggests that the hole needs to be pre-drilled to a minimum diameter of 14mm. This seems odd as my boring tool will easily enter a 12mm hole and is specified as such. It has an 8mm dia shank.
