Novamill and Triac
VR Milling v2.28
Description of problem:
Machines will not respond to cutter compensation or peck drilling codes. G codes 40, 42, 42 and 83 respectively.
Are there functions in the normal G code series that the machine or software cannot handle? If there are, is there a fix for that issue? If not, please advise what codes will not work properly in order to rewrite my curriculum.
Thank You,
G Code Problems
Cutter compensation worked on V2 milling, but was not very reliable. The software was completely re-written for this feature in Version 5 milling.
Again, G83 peck drilling has been re-written for version 5, and also works reliably.
Unfortunately, we can't support V2 milling for problems like this - thats why we did a lot of work on ironing out problems and adding features for version 5
Sorry for any inconvenience this may cause, however, an upgrade to V5 may well be worth doing.
