Z-Axis Offset Problem
Posted: Wed 24 Jan , 2007 22:44 pm
Hello,
Since I upgraded to VR Milling version 5 I have had a problem setting the Z-Axis offset. If I do not set the Z-offset less than about 12mm below the bottom of the tool a Z-Axis error message comes up when I press exlamation mark in the program, this means that I can no longer machine as thick materials as I used to with the older software. Any help with this problem would be greatly appreciated.
Jimmy
Jimmy
