I get script error when running VR Milling Tutorials
Posted: Wed 15 Nov , 2006 13:12 pm
When running the tutorials which guide you through setting up the machine and cutting a test piece, I get script error and there are blank images with a red cross in them
Posted: Wed 15 Nov , 2006 13:14 pm
A script error, or the ShowMe button being missing is an indication that Macromedia Flash is not installed on the system and/or javascript is disabled under Internet settings.
The tutorials are Compiled HTML files (*.CHM) which basically means its like a web page and uses Internet Explorer to view the content. They require javascript and Flash to be installed in order to work correctly
Download and install macromedia flash from here:
https://www.macromedia.com/software/flashplayer/
An oldish version is also on the VR Milling CD-ROM under d:\Flash Player
Also look at your Internet explorer settings to enable Javascript (Tools -> Internet Options -> Advanced)
VR Milling tutorial
Posted: Thu 16 Nov , 2006 11:19 am
by dmartin
Hi Graham,
I've done all of the above & still get the error when clicking on the "do it now" button.
"object does not support this property or method"
Dee
Posted: Fri 17 Nov , 2006 11:12 am
What OS and IE version are you running ?
Something like windows 98 and Internet Explorer 5 or less may cause problems like this.
Posted: Mon 20 Nov , 2006 9:21 am
by dmartin
We are running Winxp sp2 with IE6. It is on a RM CC3 network, but that should not be an issue, as i am currently testing with systemadmin account.
Posted: Mon 20 Nov , 2006 10:51 am
It must be a class registration issue -
can you check this registry key exists and has the same values:
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\MIME\Database\Content Type\application/x-shockwave-flash]
"Extension"=".swf"
"CLSID"="{D27CDB6E-AE6D-11cf-96B8-444553540000}"
The above class ID number should appear in a number of places in the registry, if flash is installed.
BTW - are you accessing the tutorials from the Help menu inside VRMilling ?
Posted: Mon 20 Nov , 2006 10:59 am
Just found this technical note on the Adobe website:
https://www.adobe.com/cfusion/knowledgeb ... d=tn_19091
Looks like you could try to installing Flash Player 9.0.16.0 to overcome the problem
Posted: Wed 29 Nov , 2006 10:36 am
by dmartin
I removed flash player & installed V9 as above, no change.
In answer to your question yes we are running tutorial from VR milling, Help.
Posted: Wed 29 Nov , 2006 10:42 am
I don't really know what else to suggest
Can you attach some screenshots, and show the full error message you are getting.
It all points to flash (*.swf) files not being allowed to run on your browser.
Try this shockwave and flash test page:
https://www.adobe.com/shockwave/welcome/
Re: I get script error when running VR Milling Tutorials
Posted: Fri 14 May , 2010 14:32 pm
I have the same error.
Posted: Fri 14 May , 2010 16:20 pm
by Steve
Go to the C:\Program Files\Denford\VRMilling5\Tutorials folder and see what is opening the file by default.
See attached screenshot
Can you open the ttorials by double clicking here?
Posted: Tue 18 May , 2010 10:43 am
Sorted,
I installed service pack 3 after to speaking to Admin.
