Access Violation
Ansel
Hardware/Software: VMC 1300 PRO
QUICK CAM 2D
VR MILLING V5
QUICK CAM PRO
Access Violation
Post by Ansel » Thu 16 May , 2013 14:56 pm
Hi Everybody!
First, I have a problem with the VR Millinng V5 software in some pc, when I install the software and later try to run it send me a message Acces violation at address 00694F9F in module VRMilling5.exe. Read of address 0000 0000.
The pc have a AMD Athlon X 2 Windows 7 Enterprise 64 bits
I appreciate your help.
Re: Access Violation
Post by Denford Admin » Thu 16 May , 2013 15:47 pm
When exactly does the error occur ?
Which version of the V5 milling software have you installed ?
Ansel
QUICK CAM 2D
VR MILLING V5
QUICK CAM PRO
Post by Ansel » Mon 20 May , 2013 20:52 pm
It´s the version 5.48.0.610
The error occur when try to run the software for first time.
Post by Denford Admin » Tue 21 May , 2013 9:12 am
With the current VR Milling program, an error with that address is related to Sub Programming (ie, calling one CNC program from another, running it and returning to the calling program)
This doesn't add up really, as you say it appears when the VRMilling is first run.
Can you install the latest v5.54 from here and see if the error address changes:
https://website.denford.ltd.uk/index.php ... -downloads
