VR Milling v5.47 released 30th Nov 2011
Post by Denford Admin » Wed 30 Nov , 2011 14:45 pm
Check here to download the latest version of all software:
v5.44 - changes in Gerber Reader to make circles more accurate - found that area fills using circles were leaving gaps between passes (found this from an eagle output)
v5.44 - changes in Gerber Reader to make Polygon aperture work correctly now (eg %ADD40P,0.0574X8*% is an 8 sided polygon, 0.0574 wide (diameter))
v5.44 - made an M99 clear any G92 offsets that had been programmed. Found we had a cut&paste program where the last section of pgm activated G92 shift which then meant M99 repeating still had that offset active
// ...this caused an exceeds limits error message when the program restarted running again.
v5.44 - now remembers which source was selected after restarting the program
v5.44 - BigMint changed to slow homing speed on Novamills retrofitted to latest USB, CE, ROHS and 5414 firmware
v5.44 - BigMints, added ATC stuff for retrofitted Novamills to latest USB, CE, ROHS and 5414 firmware. nb, add the ATC fitted link (In23) as per the other mc's
v5.45 - Fix to read machine disk - wasn't restoring _4axis mints properly.
v5.46 - seckey form changed to allow for bigger names
v5.46 - bigmints altered to lower the accel on VMC machines
v5.46 - re-released 5.46 for bigmint4 change to MRC40
v5.47 - made a change to set the feedrate to low, from VR, when machine not safe. even though the mint was overriding the feed you could still jog quickly the 1st time (this only
happened if you homed, opened the door and went straight to jog. although could not reproduce it on testrig with same m/c (6600) selected ?!
