VR Milling v5.42 released 3rd May 2011
Posted: Wed 04 May , 2011 9:30 am
Check here to download the latest version of all software:
v5.42 Some updates to help when decimal seperator is not a decimal point
v5.42 changes to improve jog feed control when in inch mode on the micromill
v5.42 fix for arcs on large tools in 3D simulation- update fixed in Denvrxm.ocx
v5.42 added then removed some debugging for issues in Brasil with NAN - currently this version working ok
v5.42 changes to do with copying installed appdata into users documents
v5.42 fixes to control panel and control knobs when on 125% large font/DPI setting
v5.42 changes to do with pausing mid cycle
v5.42 fixed issue where you are unable to zero the 4th axis counter (due to changing a component)
v5.42 fix to block searching advanced mode not moving to position.
v5.42 fix to block searching when re-starting on an arc move.
v5.42 uses new seckey license installation at the end of installation
