Debugging connection problems in v5 milling
Posted: Thu 23 Apr , 2009 9:23 am
There is a communication debug screen in Version 5 VR Milling, which can sometimes help see what's going on when you try to connect to a machine. To activate this window:
Close VRMilling
Locate the file VRMilling5.ini which should be located here:
C:\Documents and Settings\USERNAME\Application Data\Denford(where USERNAME is the name you log on with - if you don't know this, then click START > RUN... and type CMD into the command box..the command prompt window which appears should show your current login name in the directory)
Open VRMilling5.ini in notepad (double-clicking should do this by default)
Find the entry
MintDebug=false
and change to
MintDebug=true
save and close the file
Start VR Milling 5 again - when you connect to a machine the debug window will now appear
Re: Debugging connection problems in v5 milling
Posted: Thu 15 Sep , 2011 11:07 am
fyi the debug screen looks like this:
