VR Milling v5.26 released November 6th 2008
Post by Denford Admin » Thu 06 Nov , 2008 16:42 pm
As usual, get the latest version from here:
http://www.website.denford.ltd.uk/suppo ... -downloads
// 22/5/2008 v5.24 - XZ arcs being drawn wrong in VMC simulation (also wrong in Novamill, Triton, Triac and Micromill) - fixed by changing arc angle sent to VR world
// 22/5/2008 v5.24 - support for ROHS Orange Led ESB boards
// 3/7/2008 v5.25 - Made changes to VMC1300 mints -manual pb input 7 to turn on drawbar release (output 5) when pressed and door open and spindle stopped
// - Also changed it to lock the guard when in auto toolchange cycle
// 7/7/2008 v5.25 - Changed ImportWizBillet so that you have the option to turn off autojoining of entities
// 7/7/2008 v5.25 - Fixed a circle expand bug in Postprocessor output in QuickCAM2D- if the XY arc start and end points had different Z values
// 29/7/2008 v5.25 - DXF import is creating silly big Z values on vertical router (PB reported) - fixed it and limited auto block thickness to 40mm
// 06/08/2008 v5.25 - VMC mints altered to have a scaling factor input 16 (55xx mints only) - drawbar release button also added to input 7
// 11/08/2008 v5.25 - Added COMMS_TCRemoved so that mint can force manual toolchange messages to appear
// 3/09/2008 v5.26 - Added parameter TC Height Adjust param - default is 0 and allows toolchange Z height to be adjusted up or down
// 08/10/2008 v5.26 - Fix in Draw2D3D to NOT change the arc angle for VMC / novamill etc.. when its a XY arc - only XZ
// 18/10/2008 v5.26 - Made the file overwrite create a new unique file when trying to run from USB stick and copying to the harddisk. (You are about to run a CNC program from a removable disk ...)
// 5/11/2008 v5.26 - Fixes to make last_x y and z correct when in an incremental drilling cycle in a subprogram (eg, G81)
// 5/11/2008 v5.26 - Fix made to removable drive warning, so that if you are in single step mode, it doesn't keep asking you to run from another location every time you press start
