Billet Resolution Set too low ??
Posted: Wed 07 May , 2008 19:02 pm
by Benny
Customer writes in:
I am running VR CNC Milling v. 2.30 but when running the 3D simulator, the images are garbled and not clear. Any ideas
Posted: Wed 07 May , 2008 19:04 pm
by Benny
Your billet resolution may be set too low. you can set the billet grid size by clicking on the 3D window (this enabled the 3D setup menu at the top). Then select the menu "3D setup" > "Options. Then change the 3D grid size (mm) to say 0.2. This will give better results, but may be slower to rotate the view and update.
