VR CNC Milling v 5
Benny
VR CNC Milling v 5
Post by Benny » Fri 30 Nov , 2007 21:25 pm
I cannot locate my offset buttons, they are all grayed out.
Benny
VR CNC Milling v 5
Post by Benny » Fri 30 Nov , 2007 21:26 pm
Are you using your VR CNC Milling software on a network or do you have some sort of security/spyware software loaded such as Fortress, etc.? If so you may not have full access rights to your VR CNC Milling software. Call your IT person at the school to resolve.
If you are using the VR CNC Milling on a dedicated computer that is not connected to the school network nor does it have security/spyware software, you may have a corrupt file and need to remove /reinstall your VR CNC Milling software. Before you remove the software, make sure you can locate your security registration floppy. After the reinstallation, make sure you select/make active the correct machine.
Benny
VR CNC Milling v 5
Post by Benny » Fri 30 Nov , 2007 21:27 pm
Reinstalled software now back up and running perfectly!
