Catastrophic error!
philipb
Catastrophic error!
Post by philipb » Thu 05 Jul , 2007 14:35 pm
I am getting the above error when trying run a program using the virtual machine.
Post by bradders » Fri 06 Jul , 2007 7:21 am
When does the error occur as soon as you press the VR Machine button?
Does the software connect and run your machine OK?
Has the VR option run OK before ?
What version of VR Milling are you using ?
Post by Denford Admin » Fri 06 Jul , 2007 8:42 am
"Catastrophic failure" is something to do with OpenGL 3D - check and update your graphic card drivers.
Confirm the problem by reducing hardware acceleration to None (see this post for details on how to do that: viewtopic.php?t=289)
