RS-232 error when using new Lenovo desktop running XP Pro connected to Denford Triton milling machine.
The VR Milling runs OK but unable to connect thru RS-232 cable on PC.
Denford repair rep moved the RS-232 cable to his laptop and had no problem connecting and using the Triton machine.
Cable and Triton OK.
Any help???
Denford Triton RS-232 cable error
RS232 cable error solution
I found the answer to the RS232 error problem.
The PC I was using had ROLAND software on it and the ROLAND software took control of the COM port and did not let VR Milling software access the COM port.
Removing the ROLAND software solved the problem.
