Machining aluminium
Sarah Williams
Machining aluminium
Post by Sarah Williams » Wed 22 Jan , 2014 16:30 pm
I have a Router 6600 pro and I would like to be able to machine aluminium. Do you have a machining plan? (The closest thing supplied is hard wood/acrylic.
:o
Sarah
Re: Machining aluminium
Post by Martin » Wed 22 Jan , 2014 18:08 pm
Are you using VRMilling to create the G & M code file?
If so make sure you have the machine type set to the Router 6600 PRO.
The settings for aluminium are. Feed Rate = 400, Spindle Speed = 18000, Step Down = 30%.
Sarah Williams
Post by Sarah Williams » Thu 23 Jan , 2014 11:11 am
Thank you , I am using VRMilling but I don't know what a G&M code file is. Is it .qpp? Do I just take existing denford supplied plan and edit it to the numbers you suggest?
Post by Steve » Thu 23 Jan , 2014 12:56 pm
How are you creating the program? If using the DXF import or quickCAM 2D design then the material library in the VR Milling will be used.
Make sure you are running the latest version of VR Milling as easlier versions did not have aluminium in the material library.
If you are manually programming have a max depth of cut 30% of the tool diameter and Feed Rate = 400, Spindle Speed = 18000
6600pro materials.jpg (174.75 KiB) Viewed 9182 times
Post by Martin » Fri 24 Jan , 2014 8:24 am
If you don't have the PRO machine selected or are generating using QuickCam 2 D Design on a computer without VRMilling installed then no ferrous materials are shown in the material list.
Sarah Williams
Post by Sarah Williams » Tue 28 Jan , 2014 11:17 am
Thank you - has worked a treat! :D
