Install site licence manually
- bradders
How do i install a site licence manually
- bradders
To install site license manually from a license flash disk floppy:
Open up explorer and browse to A drive (floppy)
Double click file flash.ini - if asked what to open it with then choose NotePad.
In Notepad, select all the text as in this example:
[FLASH]
FLASH_USER=School Name
FLASH_CODE=2234-4X25-5ASE
Select COPY (CTRL-C) or use the menu for copy
Now close the Notepad file
Browse the C: drive to where vrmilling is installed
eg, C:\program files\denford\vrmilling
! Close down VRMilling if it is running !
Double click on windmill.ini - open in notepad again if asked
Insert a couple of blank lines at the top of the file
Put cursor at top line and click PASTE (or CTRL-V)
The flash entry will now appear at the top of the file.
Close the file and VRmilling will now be registered
[FLASH]
