MasterCAM post processor files
These .pst post processer files will enable you to create suitable G-code programs for our older range of machines
Denford generic mill:
https://www.denfordata.com/downloads/usa ... enmill.pst
Denford generic lathe:
https://www.denfordata.com/downloads/usa ... enturn.pst
Denford Router:
https://www.denfordata.com/downloads/usa ... router.pst
Denford Novamill:
https://www.denfordata.com/downloads/usa ... vamill.pst
Denford Novaturn:
https://www.denfordata.com/downloads/usa ... vaturn.pst
Denford Router:
Denford Novamill:
Denford Novaturn:
Some more info...
If you are a Mastercam user, these posts can be used to generate CNC programs for Denford machines.
These MasterCam post are for older (> 5 years ?) versions of Mastercam.
Please contact MasterCam directly for a more current version of the post.
Please refer to your Mastercam documentation for help.
All Mastercam post files end with a .pst extension and should be copied into the Mastercam directory.
There is suppose to be a TXT file that goes with all .PST files. due you have these?Denford Admin wrote:Some more info...
I will review updating the mill post to Mastercam X series and see how they work and post back.
Cadcam-your mastercam support
I took the post file updated to MastercamX2 or higher. created a quick path posted with no issues.
I need some one to test and see that it works ok on there machine or at least review the code to see if there are issues.
Thanks cadcam. this post update will only work in X2 and higher. if you have a lower version and need this for that version let me know by posting here.
I forgot to mention this contains the .pst and a control def and machine def.
- DenfordmillMCX2.zip
- (11.21 KiB) Downloaded 1715 times
Re: MasterCAM post processor files
Visit the following site to get MasterCAM post processor files for a range of Denford machines.
https://www.mastercam.com/TeachersStuden ... fault.aspx
Which post would be best for a Microturn Lathe? Thank you for posting these.
It will be the Generic Lathe:
If you have a newer version of masterCAM use any Denford Lathe post.
Great thank you
