Easiturn Conversion
Posted: Wed 02 Dec , 2009 21:43 pm
I'm part way through turning a control-less easiturn3 into a working lathe.
I'v used control card and software from EaziCNC (CDE) which has been great to work with, especially for someone who last did contol wiring a good few years ago!
The lathe was complete but missing the PNC 3 control and the stepper motor drivers within it.
A CDE M401 card (serial controlled from the PC) is the front end, running CDE's EaziCNC3 software. 24 volt transformers a couple of rectifiers and capacitors and a pair of ARC Euro 4.2 amp stepper drivers have given me a working machine!
I had a try today at turning out some clevis pins for the model Loco as the sort of repetitive work I wanted to avoid on the manual lathe. Nice to see the machine changing spindle speed and feed rate smoothly and the end result was a fairly quick half dozen parts with a great surface finish and all to nominal size. Manual tool changing at the moment but hopefully that will alter soon!
All I need now is to sort out the second, single pulse unit for the spindle encoder and I'll be off screw cutting too!
John
John
