harrison vs280 cnc lathe with denford controler year 1990
Gerry3D
Post by Gerry3D » Tue 23 Mar , 2010 23:16 pm
hi every one
has anny one camacross a harrison vs280 cnc lathe with a bbc micra computer
and a controle bord is a bradford instroments ltd the other bord is a
mw controlers ltd with digiplan drives. it has got a 8 station tool post.
and how wood i go about retra fitting this machine as the controlr
is ded
thank you anny help much abricated
Re: harrison vs280 cnc lathe with denford controler year 1990
Post by Steve » Wed 07 Apr , 2010 12:45 pm
I think you will find that this machine was Manufactured for Harrisons by MW Controls. :oops: (I used to be General Manager there some years ago).
MW Controls were the electronics division of Boxford Ltd.
The rack control card should be of use as it has parker digiplan drives and power supplies fitted. I also think there are buffered clock cards slotted next to each of the drives. These handle the ramping to prevent stalling if too high a feed is requested.
I would see if you can find any help from Boxford as they still work with Bradford Instuments.
Good Luck!
