Arcs being generated the wrong way round
We are using v1.3 of quickcam 2D and the arcs are being output the wrong way round occasionally - eg, a CW arc is being change to a CCW arc.
We have found that this problem is related to AMD64 processors storing numbers slightly differently.
It has now been fixed, and will be released shortly in v1.4 - this also goes for LaserCAM 2D.
In the meantime the problem can be fixed by turning off the option to convert lines to arcs (Menu -> Generate -> Convert Output To Arcs)
