QuickCAM 2D v1.11 released 25th Feb 2010
Posted: Thu 25 Feb , 2010 12:27 pm
// 1.11 - made some changes to wmf import because stuff was coming in stretched
// 1.11 - added more fonts to prog files\denford\common
// 1.11 - allows multiple polylines to be selected and the fill property changing. position properties will effect the 1st selected only
// 1.11 - Align and distribute multiple entities - also added quick keys INSERT / HOME / PAGEUP to perform Align LEFT / CENTER / RIGHT
// 1.11 - added quick key G to group items
// 1.11 - Fixed drag/drop of .EMF / .WMF and .GB files
// 1.11 - Altered material editor so that minimum stepdown is 1% not 10%
// 1.11 - Added chamfer and fillet - any selected polylines will have all corners filleted or chamfered.
// 1.11 - Fixed a problem with ellipses (eg from .wmf) not appearing in the CAM wizard
// 1.11 - altered default .mof file to match vrmilling5 where the library now reflects the tools available when ordering a machine
As usual - check here for the latest version:
