parting ali help
Moderators: Steve, Mr Magoo, Martin, bradders
hpe
parting ali help
Post by hpe » Wed 12 Jun , 2019 18:47 pm
i have a cyclone with a toe80 toolchanger .its all working mach 3.
i have a 3mm hss parting tool (ill buy different if advised)
i am struggling to part 25mm aluminium with it .
its snatching grabbing sounds terrible vibrates .
i can see the tool lifting a bit.
if something is loose or worn i will fix it,
But i need a base to start with
with this machine and tool what rpm and feed per rev do owners of this machine use for parting 25mm aluminium
cheers
Re: parting ali help
Post by Martin » Thu 13 Jun , 2019 7:52 am
Aluminium is difficult to part off without coolant.
We use Free Chipping Aluminium grade 2011 T3 without coolant.
With the following Feeds/Speeds.
Feed Rate/Min = 120
Feed Rate/rev = 0.07
Spindle Speed (RPM) = 1800
Spindle Speed (CSS) = 135
hpe
Post by hpe » Fri 14 Jun , 2019 7:47 am
thanks
So with these settings i should be in the ball park?
Regarding the parting tool lifting , does this suggest faulty turret with too much play or to be expected if settings are way out ?
thanks
