Secret HOME button on VR Milling V 2 & V 5
- bradders
Secret HOME button on VR Milling Ver 2
Why use the secret Home button?
The reason you may want to do this is normally for fault diagnosis reasons.
If a machine will not go to home for some reason. It could be that there is a piece of work jamming the slide or a build up of swarf. You may want to jog the slide away from home to allow you to clear the obstruction.
By pressing the secret button you are allowed to get into Jog mode without going through the home procedure.
Once you have resolved the problem you should go back to HOME and HOME ALL AXES before operating the machine
Never operate the machine in Auto mode without homing the slide as the position the slide is in when you click the magic button is where the home position would have been set
Re: Secret HOME button on VR Milling V 2 & V 5
Note: Once you have clicked the secret home button the JOG option becomes available.
I am impressed.
Does it work if I hit the E-Button? My new users always stuck, when they hit the E-Button.
Best regards,
David Fhu
“Dream as if you'll live forever, live as if you'll die today.” - James Dean
David Fhu
Hitting e.stop will always force the software into HOME mode - this is because under emergency stop, the axis positions are cleared.
It will be possible to use secret home once emergency stop is released.
Note that this function should only be used if there has been an accident with the machine, and an axis needs moving before it can home out as normal.
Hi, Denford Admin.
Point Taken. Thank you.
Best regards,
David Fhu
David Fhu
- Hardware/Software: Conect Numerical control 250 machine
Denford VR CNC Milling software
Can you help us out , my z axis seems to be sticking . Can i use this method to get it out ? it seems to be trying to go -50 for some reson ? not sure how to get out of this ?
