Parallel PCMCIA Card to provide additional Mach 3 I/O's
hpdrifter
Post by hpdrifter » Sat 11 Jul , 2009 10:32 am
Has anyone had any tried using Parallel PCMCIA Card (ie additional printer port) to provide additional Inputs and Outputs to Mach 3?
Will this work and can Mach 3 be configured to see it?
I am using a laptop and all my I/O's are being used to control my ORAC lathe.
I have just designed and interface board to an 8 station tool changer and require additional inputs.
Any feedback would be appreciated.
Best Regards
Triac whizz
Re: Parallel PCMCIA Card to provide additional Mach 3 I/O's
Post by Triac whizz » Sun 12 Jul , 2009 7:37 am
They don't work, they're not proper parallel ports, you're rather lucky that a laptop works. Usually all their built in power management stuff trips up mach.
www.la-coterie.com
hpdrifter
Post by hpdrifter » Sun 12 Jul , 2009 11:40 am
I am getting a little confused now!
I use mach 3 on laptops on several NC machines and have never had any problems.
Secondly, feedback from the mach 3 forum is telling me that Parallel PCMCIA Cards should work fine.
I need to go back to my first question has anyone actually tried this method of providing addional inputs.
Any other comments would be welcome.
hpdrifter
Post by hpdrifter » Sun 12 Jul , 2009 12:05 pm
The answer appears to be yes if you look here
https://www.machsupport.com/forum/index. ... 657.0.html
