I have a problem replacing the two micro switches in the saddle of a denford easiturn 3. The wires for these seem to run through cored and drilled holes in the castings (the one from front to rear seems blocked) so
it seems the saddle may have to be split and the top half removed in order to clear it. any info. would be welcome.
Denford easiturn 3 cnc lathe
Had a quick look for a limit switch arrangement drawing, but only found one for the EasiMill - SK760
Have a look at the sketch book, and if there is one you find usefull, I'll be able to post a photo of it:
viewtopic.php?t=906
viewtopic.php?t=906
- Triac whizz
If you mean the micro switches for the X then to get at them you have to remove the slide which isn't too bad. (or have you already done that? I don't remember where the wires went though
The switches for the Z are at each end of the bed so no worries there
www.la-coterie.com
www.la-coterie.com
Re: Denford easiturn 3 cnc lathe
thanks for your assistance I will be able to do as you say but I dont know where the six wires connect when they en
ter the small metal box at the rear. Also not sure how the two metal plates under the crosslide go in.Thank you Ted
