TU150P startup problem
Ojones
Hardware/Software: TU150P
Post by Ojones » Sun 22 Mar , 2020 21:18 pm
I've recently purchased an ex college TU150P, i know the machine has been standing for many years, so had to replace the memory batteries and I’m assuming all the parameters are lost. On powering up i get alarm 100 P/S and NOT READY ALARM flashing. Before I start checking cables etc.. would anyone have any suggestions on where to start?
Re: TU150P startup problem
Post by Martin » Mon 23 Mar , 2020 11:23 am
It may be worth resetting the control.
Have you got the full list of parameters & diagnostics?
I presume it has a Fanuc OT-A control fitted.
Ojones
Post by Ojones » Tue 24 Mar , 2020 14:26 pm
Yes it is a Fanuc OT-A, I've got a manual which has all the parameters (some are printed and others hand written) would the diagnostics be with these? How would i go about performing a full reset? Another question before i do this, if i cant start the spindle and test motor rotation, could the phase sequence be wrong in the plug and cause the machine not ready problem?
Post by Martin » Tue 24 Mar , 2020 19:34 pm
No the phases should not cause an issue.
It may just be on an limit switch. Press & hold in the axis limit override button on the side of the control panel for a few seconds & home the axis while pressed if it clears.
Also it may need a dummy plug in the Auxiliaries socket on the side of the electrical cabinet.
Ojones
Post by Ojones » Sat 28 Mar , 2020 11:00 am
Ive tried homing and nothing works, ive also wound both axis away from the switches by hand. The auxiliary socket doesn’t look like its ever had anything plugged in but i could try putting some links in if that might work.
If i wanted to perform a complete reset as mentioned before and input the parameters from scratch, how would i do this and what would be the pros and cons?
