NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1
- Iron-Man
- CNC Apprentice
- Hardware/Software: Modified NovaTurn with Yaskawa AC Servos +-10V, PathPilot running on a GizmoSphere 1 with Ibob2 PCIE interface that I designed. Denford Triac to be modified with AC Servos.
Hello all!! I have been very busy working on several projects. I have started my retrofitting of a NovaTurn. I will be using Yaskawa AC servos 100W. I will post more pictures and video soon. If you want to see some basic videos please go here;
CNC https://www.youtube.com/watch?v=Zg8HZzmHRtQ
Sound Card https://www.youtube.com/watch?v=E1Xj6C5Uq2I
I have demonstrated Ubuntu 10.04, LinuxCNC and Windows 7, 32bit-MACH3 using a MESA 6i25 for closed loop analog servo control and a PCIe x1 parallel port card to breakout board for open loop stepper control.
In a previous post a few years ago, the unit does not have the controller cabinet. I am designing a new unit. It will be very small.
The Gizmosphere is approx 3.96" x 3.96". The iBOB2 is approx 2.5" x 2.56" in size.
To Admin, I would love to demonstrate your software running on this system if possible.
I welcome any comments or thoughts.
I am still interested in locating a tool turret for this lathe if one is available.
Thanks,
Robert Blanton
Thanks,
Robert Blanton
- Start of retrofit.
- Yaskawa Servo 2015-03-04 14.28.18a.jpg (250.34 KiB) Viewed 31453 times
- Iron-Man
- CNC Apprentice
Re: NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1
The "Schematic Circuit Diagrams for the Novaturn" reference SHEET number 4, for the 42 way connector. Sheet 4 is not part of the circuit diagrams. Is sheet 4 available?
Thanks,
Iron-Man
Thanks,
Iron-Man
- Iron-Man
- CNC Apprentice
Just finished the new X axis servo motor plate. I used my converted Sherline Mill with DC servo amplifiers that I built/designed a few years ago. If anyone is interested, please let me know. Most of the initial work is posted on CNCZONE under Iron-Man Servo. I will be powder coating the parts. I have already started the new design for the Z axis servo plate.
I welcome any comments.
- Sherline Mill Servo Plate X Axis
- Yaskawa Servo Plate X Axis Mill 2015-03-17 20.28.49.jpg (132.5 KiB) Viewed 31408 times
- Yaskawa Servo Plate X Axis 2015-03-19 17.45.17.jpg (82.47 KiB) Viewed 31408 times
- Iron-Man
- CNC Apprentice
Completed Z Axis Servo plate. X Axis Servo plate trial fit. The Z Axis did not come out as planned. I may redo it. I will also be retrofitting a Denford Triac Mill with Allen Bradley AC Servos.
- Sherline Mill Z Axis Servo Mount
- Sherline Z Axis Plate, 03-29-2015web.jpg (426.73 KiB) Viewed 31383 times
- Test Fit X Axis Servo Mount
- Test Fit X Axis Servo Plate 1, 03-27-2015web.jpg (427.29 KiB) Viewed 31383 times
- Z Axis Servo Mount Polished
- Z Axis Servo Plate Polished, 03-29-2015web.jpg (229.71 KiB) Viewed 31383 times
- Iron-Man
- CNC Apprentice
Picture of iBOB2. The iBOB2 turns the Gizmosphere 1 into a powerful CNC controller. You can attach Mesa cards, parallel port cards or any PCIe compatible card.
- iBOB2 PCIe x1 interface card.
- iBOB2 ver 2small.jpg (240.13 KiB) Viewed 31368 times
not much metal left on the inner wall of those slots! I'm sure you have thought about that. Good work!
- Iron-Man
- CNC Apprentice
Thanks for the comments. I am trying to make as little modifications as possible. The piece is 1/4" aluminum and is very strong. When I get the Triac retrofitted, I may redo the parts in steel.TDIPower wrote:not much metal left on the inner wall of those slots! I'm sure you have thought about that. Good work!
Iron-Man
- Iron-Man
- CNC Apprentice
From This:
To This:
The I/O shield is now ready for powder coating.
To This:
- Iron-Man
- CNC Apprentice
Assembly drawing ST6_0700 shows a # 2MT taper inside part # ST5/703, are the dimensions of this part available? In addition, is part ST5/704 a brushing / bearing?
After a little research, just figured out the part is a "Morse Taper Socket Adapter". I will try this model and adjust as needed; http://www.mscdirect.com/product/details/00185041
- ST6_0700.pdf
- (68.91 KiB) Downloaded 1346 times
- Iron-Man
- CNC Apprentice
Parts powder coated and ready for install. Currently working on the CNC controller.
- Gizmo 1 I/O Plate Powder Coated
- Gizmo 1 I-O Plate Powder Coated.jpg (327.54 KiB) Viewed 31253 times
- Z Servo Plate Powder Coated
- Z Servo Plate Powder Coated.jpg (314.22 KiB) Viewed 31253 times
- X Servo Plate Powder Coated
- X Servo Plate Powder Coated.jpg (325.82 KiB) Viewed 31253 times
- Iron-Man
- CNC Apprentice
This is what I have in mind for the control panel. I hope to build my own tool changer and C axis. The Gizmosphere will eventually be located inside this cabinet. The cabinet was not available when I started initial design work. The DC drive is a 4 quadrant "servo motor" drive.
- hardinge control panel.JPG (221.81 KiB) Viewed 31226 times
- control panel inside.jpg (412.95 KiB) Viewed 31226 times
- control panel cut out.JPG (209.14 KiB) Viewed 31226 times
- control cabinet taped layout.JPG (219.39 KiB) Viewed 31226 times
- Iron-Man
- CNC Apprentice
Cleaning up the NovaTurn and bellows. First custom I/O cable completed. Working on the CNC controller and testing servo motors.
Iron-Man
Iron-Man
- Custom I-O cable
- custom I-O cable #1.jpg (495.61 KiB) Viewed 31151 times
- bellows 2 repaired
- Bellows 2 repaired.jpg (319.01 KiB) Viewed 31151 times
- Bellows 2 before
- Bellows 2 before.jpg (337.69 KiB) Viewed 31151 times
- Bellows 1 repaired
- Bellows 1 repaired.jpg (177.45 KiB) Viewed 31151 times
- Bellows 1 before
- Bellows 1 before.jpg (268.3 KiB) Viewed 31151 times
- NovaTurn clean-up
- Novaturn clean-up.jpg (701.85 KiB) Viewed 31151 times
- Iron-Man
- CNC Apprentice
I have been working on a design based on the iBOB2 and Gizmosphere 1. The Dimensions of the GQ1 are Width 6.79", Height 6.61" and Depth 10.29". It has 6 axis of +- 10V analog servo control and all I/O are available on 2 DB50 and 1 DB 25 connector. The RJ45 is for a pendant interface. It could also be made for step and direction. I prefer true closed loop control. I plan on selling the iBOB2 for anyone who wishes to make a ultra small CNC controller or place the complete controller within a small case or enclosure.
The small circuit board in the back left is the iBOB2.
This will be used for the NovaTurn Lathe.
- GQ1.jpeg (511.49 KiB) Viewed 31056 times
- GQ1back.jpg (404.07 KiB) Viewed 31056 times
- Iron-Man
- CNC Apprentice
I need to machine my own chuck key. Can anyone post the specs and a high resolution image of the NovaTurn chuck key?
Thanks,
Iron-Man
Thanks,
Iron-Man
- Iron-Man
- CNC Apprentice
Does anyone have the exact part number for the NovaTurn encoder or data sheet?
I should be posting video of the NovaTurn AC soon.
Thanks,
Iron-Man
Thanks,
Iron-Man
it's coming on well. nice to see the progress.
- Iron-Man
- CNC Apprentice
Pete thanks for the comment.TDIPower wrote:it's coming on well. nice to see the progress.
Iron-Man
- Iron-Man
- CNC Apprentice
I have had to repair the encoder, it was faulty / defective. I have posted all the information that I could locate that might identify the encoder.
It appears to be a 755A with a 10mm shaft with flat. In the Novaturn, only A and index are used.
I modified my encoder to provide all signals, A A', B B', Z Z' which will be used for position control.
I had to replace the ET7272B as it was faulty. I may modify the case to accept a 10 pin connector for quick disconnect.
For those of you who might have a damaged or faulty encoder, please see the information below.
I am currently designing a circuit to interface the Hardinge control panel to the MESA 7i77. This circuit will control the leds and membrane switches without using any additional I/O on the 7i77.
Has anyone looked at the Gizmosphere for CNC / control applications?
I hope this helps,
Iron-Man
I hope this helps,
Iron-Man
- Encoder housing 1 2015-09-16 20.39.33.jpg (180.4 KiB) Viewed 30717 times
- Encoder Housing 2015-09-16 20.37.55.jpg (198.97 KiB) Viewed 30717 times
- Encoder Novaturn 2015-10-14 22.05.09.jpg (284.17 KiB) Viewed 30717 times
- Encoder Test Set-Up 2015-09-29 21.27.30.jpg (457.01 KiB) Viewed 30717 times
- et7272_a1.pdf
- (47.85 KiB) Downloaded 3019 times
- Encoder 755a-shaft.pdf
- (746.18 KiB) Downloaded 1623 times
- Iron-Man
- CNC Apprentice
PathPilot on AMD Gizmosphere1, T40E + iBOB2
I am almost finished. I have PathPilot running on the GizmoSphere 1.
Specs:
G-T40E dual-core processor running at 1.0 GHz, combined on a single die with AMD Radeon™ HD 6250 discrete-class graphics. The board provides a performance capacity of 52 gigaFLOPS (GFLOPS) at less than 10 watts. Custom high- and low-speed edge connectors enable a full range of functions. This unprecedented level of integration between serial and parallel processing offers a power-efficient foundation for high-performance multimedia content delivery across a broad range of embedded designs such as digital signage, x86 set-top box (xSTB), IP-TV, thin client, information kiosk, point-of-sale, casino gaming, media servers and industrial control systems.
Currently decoding I/O on the Hardinge interface. The MPG, Axis select, and Rapid Override are functioning under Linuxcnc. I just need to change the bit file and 7i77 I/O for complete functioning.
Iron-Man
Specs:
Iron-Man
- GizmoSphere 1 PathPilot 2015-11-09 20.jpg (381.48 KiB) Viewed 30622 times
- Hardinge Test 2015-11-09 small.jpg (450.2 KiB) Viewed 30622 times
- Novaturn 2015-11-09 small.jpg (345.68 KiB) Viewed 30622 times
