Triac atc carousel tool clamp gripper wanted
Moderators: Steve, Mr Magoo, Martin, bradders
angel-tech
Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3
Post by angel-tech » Thu 19 Jul , 2012 17:21 pm
as in the title i need one of the eight grippers and it's holder for a triac atc. That's the flexible gripper and the half round mount that makes up the tool holder in the carousel.
Bit of a long shot but you never know.
Re: Triac atc carousel tool clamp gripper wanted
Post by bradders » Fri 20 Jul , 2012 9:19 am
MCV2/711 Tool Holder Roller - 2 required per tool holder - £18.00 each
TR3/728A Tool Holder Spring - 1 required per tool holder - £8.00 each
These prices are ex P&P and VAT
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Fri 20 Jul , 2012 9:28 am
and i need the ally block that holds the tool holder spring in place.
Post by Denford Admin » Fri 20 Jul , 2012 10:00 am
Have added some detailed drawings of the triac tool carousel
viewtopic.php?f=47&t=3812
jamesgates1000
Serial number - H00913.
Serial number - 70826B.
Post by jamesgates1000 » Thu 01 Feb , 2018 10:21 am
Are there any of the springs still available?
Post by Steve » Thu 01 Feb , 2018 13:23 pm
The spring is still used on the current VMC1300 Toolchanger as a VMC/0721 The price is now £11.50 plus Vat
The old spring had to be drilled the new one is punched for the locating screw.
