Customer enquires...........
Machine program
N0 G71 G90 G40
N10 P22=K-436.6 F1 K34.4 ( 436.6 DISTANCE FROM CHUCK DOGS TO HOME POSITION 34.4 DISTANCE FROM DOGS TO Z ZERO OF JOB )
N20 G20 N01.1 (SUB PROGRAM TO READ JOB OFFSET AND TOOL OFFSETS)
N30 T3.3 TOOL CHANGE
Etc
SUB PROGRAM
G22 N01
P21=K-21.578 F1 K92 (X OFFSET)
P23 =K-145.451
G53=X0.0 ZP22
G50 T1 XP21 Z8.5 F3 R0.000 I0.000 K0.000 TURN TOOL H09
It is not reading the P22 when I go to the home position it should go 34.4 from the dogs for the Z zero but it take it from the home zero 436.6mm from the dog face.
Fagor Programming
- bradders
Re: Fagor Programming
Admin replies......
This means
Set Parameter(or variable) #22 to -436.6+34.4 (which = -402.2)
F1 is the Add command
K just means read this as a constant number
So doing G0 ZP22 should move the Z axis to -402.2
If that’s not the front face of the billet, then either -436.6 is wrong, or the machine home position has moved.
I doubt that the axes display will change to reflect the value of P22 as it’s only a variable that can be used for any purpose.
So, the only way to be sure is to try “G0 ZP22” and see if it’s going to the correct place (Z should read -402.2 as long as there are no other offsets active)
This means
- bradders
Customer replies........
I have put line 35 in the program G0 P22 I have ran the machine in single block when it reads line 35 it goes 34.4 from the dogs but when it reads line 40 it goes 9.5 from the machine datum which is 427.1 from the dogs.
Machine program
N0 G71 G90 G40
N30 T3.3 (TOOL CHANGE)
N35 G0 Z P22 (TOOL MOVES TO 34.4mm FROM THE FRONT OF THE DOGS)
N40 G0 X10 Z-9.5 M03 M08 (TOOL MOVES TO -9.5 FROM MACHINE DATUM NOT JOB DATUM 24.9 FROM DOG FACE BUT MOVES 427.1 FROM DOG FACE)
Etc
SUB PROGRAM
G22 N01
P23 =K-145.451
G53 X0.0 ZP22
Etc
LAST LINES OF SUB ROUTINE ARE
N110 G90 G71 G40 G95
N120 G92 S2200
N130 G96 S150 M41
N140 G24
Machine program
N0 G71 G90 G40
Etc
SUB PROGRAM
G22 N01
P23 =K-145.451
G53 X0.0 ZP22
Etc
N120 G92 S2200
N130 G96 S150 M41
N140 G24
P22 is just a variable so if P22 is set to -400 then commanding G0 ZP22 is exactly the same as G0 Z-400
So if you want to shift the datum position using this P22 then maybe you should be using G92 to set the datum position.
eg,
G0 ZP22 - move to front of job.
G92 Z0 - set this position to be Z0
Then any Z values will be relative to the front of the billet
eg,
- bradders
Customer replies ..............
Yippee it works
Thanks very much for your help much appreciated
Yippee it works
