Response time
Response time
I inquired about buying software a couple days ago, what's a typical response time? In hindsight I guess what I should have asked about is actually buying a license.
Re: Response time
Did you ask on here or directly to Denford. They only come on here from time to time like us. Phone or email the office directly.
Re: Response time
Directly. I'll send another request being more specific this time.
Re: Response time
Do you know exactly what you want? If it is VR milling or Turning? you will need to supply info from the machine plate but I would also open the cover plate and get the software version off the eprom; they got upgraded over time but it might not be updated on the machine plate. You need that so you can get the correct version.
Re: Response time
I was looking for info on turning. Attached are the data plate and eprom.
- WIN_20180918_164740.JPG (601.91 KiB) Viewed 10831 times
- WIN_20180914_131815.JPG (454.15 KiB) Viewed 10831 times
Re: Response time
Is there anything else I needed?
Re: Response time
No that's all they should need, the only thing is the 32pin eprom (chip) with the little glass window should have a sticker on it saying the software version. without that it is hard to be sure if it has ever had an update. The sticker is also meant to be there to stop UV getting to the internals of the eprom, When you want to erase what is on it you expose that section to UV. I would put a bit of black tape over it.
I would give them a call.
Re: Response time
I'm still waiting on a response from my Denford US distributor about the price on a license for VR turn after more than a week, seems like it would have been a quick reply. Could anyone give me an approx. cost on a license?
I'm not 100% sure the electronics will function as they should since there doesn't seem to be a trial version of software so I could at least jog the axis. It might be more beneficial for me to choose another motion control program.
I'm leaning toward Centroid Acorn. Does anyone have experience with them?
Re: Response time
Hi, I've only dealt with Denford UK as this is where I am.
I'm not familiar with the Mirac but a machine on the 2000 year I'm not sure if that would be a DOS machine or a Windows/VR machine. IF it is a DOS machine you can get the software free, if a VR machine it would need to be purchased.
Have a look here it may help you http://website.denford.ltd.uk/dos-vinta ... formation/
You could try contacting Denford UK directly too.
Re: Response time
I have considered it's a dos machine. That presents another problem. I haven't seen a Win 98 computer in a very long time and I'm not sure a dos emulator would work.
Re: Response time
I currently run my starturn lathe on Win xp through a 'windows' DOS window so you don't need to go back to 98, just remember to disable screen saver and power saving as XP doesn't realise you are working with the PC in DOS.
Does your machine have the 'tutor keyboard'? if so then Im pretty sure that its a DOS controlled unit as I have never seen any run VR software with a tutor keyboard. I don't know If the mirac would run with the current version of VR turning and i don't know if they would still sell an old version
Re: Response time
It did come with a Tutor keyboard, so It may be a Dos machine. I downloaded Dosbox and played with it a bit today. I'd forgot what a pain Dos was. I've all but made my mind up to use Centoid Acorn and do a conversion with modern stepper drives. A license of VR turn is more expensive than a their motion controller board and software, soooo.
Re: Response time
I bit the bullet a while back and bought the Quickturn 2d software but the old DOS control board doesn't like some of the G code commands it produces so given that outlay I'm looking to convert my Starturn over to VR turning, needs the control board swapping out and a few other bits. I have the control board, just need the time! Ill have to buy VR Turning then too. When Im done it should match a Novaturn apart from my main drive motor as it is lower power/rpm than the Nova.
It took me ages to get the starturn up and running due to all those wonderful variations on RS232 lead configurations and DOC configurations.
Have you managed to get it working in DOS then? I'm pretty sure if it runs DOS it won't run VR turning.
Re: Response time
I haven't tried to get it running under Dos. I downloaded an emulator and the dos turning program to check it out. It's simply not user friendly, too many years of using Windows based programs.
