Triac PC bare bones startup?
TH3DLO
Hardware/Software: Denford Triac PC 1996
Post by TH3DLO » Thu 06 Sep , 2018 19:36 pm
I have been looking high and low for a start to finish setup on a Triac PC.
Its a 1996 build with ATC. I got it with some of the original software, and after loading it, I was not able to configure the connection details (boud rates, bits, etc).
Got the correct cable that came with the machine, now its just a matter of installing the correct software and making sure the 2 talk to each other.
Cant seem to find the right info on which file I need from the Denford legacy software site, and from what I have read those who have struggled to get the OEM software to work dont really explain how they did it, or my keyword skills have failed me.
Anyways I need to make sure the 3 axis work before I decided to upgrade to the more modern interfaces that are out there.
The computer I am using the connect to the Triac is an XP machine with a 9 pin parallel port.
Com port is set to one.
Thanks.
Some pictures cause everyone loves pictures:
rasp
Re: Triac PC bare bones startup?
Post by rasp » Mon 10 Sep , 2018 0:29 am
There should be a software version on the side of the electrical box.
TH3DLO
Post by TH3DLO » Mon 10 Sep , 2018 15:31 pm
rasp wrote:There should be a software version on the side of the electrical box.
It says;
Software Version 2.93'
rasp
Post by rasp » Mon 10 Sep , 2018 17:22 pm
Machine is usually on COM2 and Tutor on COM1 or this can be changed in the .GO file
