have some messages that appears during booting from diskett :
640k Base memory,00384k extended
Invalid configuration information-please run SETUP program.
Strike the F1 key to continue.
F2 to run the setup utility
( with the original keyboard i get message :
Keyboard failure
F2 to run the setup utility. )
The original keyboard is not responding at all.
When I use an other external keyboard, I am able to get into bios that tells me that bios time is lost. when I set up new time and year and continue i get following errors :
error 241 No keyboard present
rs 232 driver removed
error 128 software aborted
every time I reboot (even with power on) the bios clock setting is "lost"
I belive also the PC in this machine have no Harddrive.
I have no experience with this machinetype.
any ideas anyone ?
best regards
Denford model Triac serial EO 3995
Sounds like an old DSP rack-computer, and the CMOS battery has failed
Have a look at this to see if its like the hardware you have:
viewtopic.php?t=349
other information in the rack PC's from this forum:
post some photos if I've got the wrong end of the stick
viewtopic.php?t=349
andThe euro PC card was from a company called DSP Design Ltd in Chesterfield: www.dspdesign.com
Hope this helps,ASRS Cyclone Tu150 DSP SETUP
CMOS SET-UP
(Rack type p.c's)
If the p.c. is left with power disconnected for a long period of time, the on board battery may become drained.
This results in the p.c. suffering a "loss of memory".
To re-establish settings use the following procedure.
Turn on computer.
When screen displays:
Starting MS DOS.......
Depress Ctrl+Alt+S keys simultaneously to invoke the set-up procedure.
A menu will now appear in the centre of the screen giving set-up options i.e.;
Setup
Extended BIOS Features
System Information
System Security
Using the cursor keys highlight the option "setup", and press return.
Screen will display certain values.
Adjust values to 3-1/2" floppy drive 1.44 M then press F10.
A dialogue box appears to confirm that the changes have been saved.
Press Esc twice to exit setup.
The p.c. will now reboot.
