Hello, can anybody help me with a Triac mill running Heidenhain 2.98 software using a desktop tutor. I'm having problems running programs which have more than 10mm Z depth, I've written my own cycle which moves incrementally -2mm then I label call and repeat 5 times program runs fine, if I change the reps to 6 machine reports error "machine limits exceeded". It's the same with any pecking or pocket cycle. The way I am getting around it at the moment is to running cycle through then alter the offset and run cycle again. Any information on this matter would be gratefully received.
Regards Dale
Help with Triac mill using heidenhain v2.98 and desktop tuto
- CNC Apprentice
- CNC Apprentice
I found the problem, at the start of the program it must have blk form details entered. The first line is coordinates of x0 y0 z enter maximum program travel (minus). Second line is size of billet. It does ask for min and max corner radius on each line but I am not to sure what radius it's referring to.
Its a big download, but we have the Heidenhain TNC 355 programming manual here:
viewtopic.php?t=1173
