I have a Microturn 2000
When in the jog mode the arrow keys on the key board do not work.
I have reloaded the software and have changed out key boards and that didn't work.
What have I missed/
Help!!
HITech
Arrows on key board doesn't work
HITech is the Exclusive Denford Dealer for Pennyslvania & New York.
Brian Haskell is the former National Sales Manager for Denford from 1994-2003.
Jog Keys not working
I am having the same problem on VR milling 2.31. I have updated the software, changed default jog buttons, and changed the feed rates. The axis positions numbers are not changing at all.
The home button seems to work. The default coordinates are 0,0,0 and they move slightly when I click 'Home All', and return to 0,0,0.
I am connecting to a Microrouter and have tried selecting different machines in the "Setup Machine Parameters.." (ROUTER, ROUTERV3, ROUTERV3PRO, etc)
In all versions of VR Milling and Turning, the Jog mode has to be selected, and there will be a green indicator to say that its able to jog.I am having the same problem on VR milling 2.31
If you click on another window the Jog control panel looses focus and you aren't able to jog.
It could also be down to feedrate override - the system may think you have an external override pot fitted where there isn't one - resulting in a permanent override of 0%.
Usually the default parameters are correct, but some machines can be different to the default.
Are you sure the jog keys are changed to what you wanted ?
Remember that each machine you have tried will have its own setup for the Jog keys
