VR Turning v1.29 released 24th Aug 2012
Posted: Fri 24 Aug , 2012 15:45 pm
// v1.29 - fix to Carousel and offsets form to allow you to type in offset values properly
// v1.29 - change to Carousel and offsets form to allow editing of any offset available - datum set buttons only available on current tool though
// v1.29 - added to Carousel and offsets form measured difference form to let you input measured sizes against programmed and it will alter the offset accordingly
// v1.29 - added menu File>Print>Offsets to let user print work and tool offsets out
// v1.29 - fix for workoffsets - didn't update tool offset if tool changed while workoffset window was open.
// v1.29 - added measured/actual difference buttons to workoffset as well as tool offsets.
// v1.29 - bug fixes to G42 cutter comp
// v1.29 - changes to BigMint2 so that M03/M04 wait for spindle to get to speed properly (within 10%)
// v1.29 - updated to new Installation - any issues to do with files not being found or registered (.ocx's) will be down to this
Check here to download the latest version of all software:
