Software hangs during a auto tool change
Help and advice for Denfords lathe control software VR Turning.
Post by Martin » Thu 12 Mar , 2009 9:44 am
Fault
During a Auto Tool Change the turret moves to the correct position & then reverses into position but the software does not register & locks up.The software is VRTurning ver 1.19 & the toolpost is a DM8.
Post by Martin » Thu 12 Mar , 2009 9:45 am
Try logging on as a Administrator. There are several files in the VRTurning directory that need read/write permissions.
Post by Denford Admin » Fri 13 Mar , 2009 10:01 am
Did logging on as Admin fix it ?
It sounds more like the Turret needs resetting by trying an M27 ?
(M27 is not available on older lathes)
Post by Martin » Fri 13 Mar , 2009 17:48 pm
Yes it was down to read/write permissions.
Post by bradders » Thu 30 Apr , 2009 14:57 pm
Do you know which Directories / Files need to be Read / Write ?
Post by Denford Admin » Thu 30 Apr , 2009 16:49 pm
The file that causes the toolchange to hang up is the machine's .ini (parameter) file.
These are located here on a standard installation:
C:\Program Files\Denford\VRTurning\Config
The software is trying to set the current tool number, for the next time the software is used
So, this folder and all its files should be able to be read/written.
In fact, all files and folders in
should be read/writable by all users.
