Page 1 of 2
ASRS drive
Posted: Thu 21 Feb , 2013 3:32 am
by umair
i have a problem with ASRS drives, it does not get hommed in the Z-axes. and in normal type of motion it does not moves in the X and Y-axes. Need help regarding the axes motors. and how can i enable the drives.
Re: ASRS drive
Posted: Thu 21 Feb , 2013 10:11 am
by Steve
Respected Sir,
I am a student of NUST(National universty of Science and technology), Pakistan.. Sir our ASRS is having a problem, it is not getting home correctly.. plus there is this error "Asynchronous axis error" and some times it get homed correctly... means the software behaviour is irregular..
if u can help me, that would be grate full.. thanks
Umair
Re: ASRS drive
Posted: Thu 21 Feb , 2013 10:12 am
by Steve
I am a student at National University Of Science and Technology. We have got CIM installed by Denford.The ASRS of CIM of serial number'AsRS E00615' is not working.
We are facing problem in troubleshooting of Asrs and folowing errors arise during its usage,
1.Whenever we 'HOME' in X and Y directions,it get homed,but when we home it in Z direction it some time donot Home at all and some time it get free motioned in Z direction and we have to push the emergency button to stop it reaching its maximum limits in -ve Z direction.
2.After reaching its maximum limit in -ve Z direction it no longer home in X and Y direction and it commonly give error "Drives not enabled".
3.Some time it gives the error "Asynchronous axis error".
4.In teach manu it does not move in any axis that is X y and Z axis.
Please guide us in troubleshooting these errors.
regards,
zaheer ud din
student
National University Of Science and Technology Islamabad
Pakistan.
Re: ASRS drive
Posted: Thu 21 Feb , 2013 10:14 am
by Steve
Sir i have a pic of the motor and electronics controlling it, but i didn't find a way to post pictures in this forum. plus how can i enable the drives..
Re: ASRS drive
Posted: Thu 21 Feb , 2013 10:18 am
by Steve
It sounds like you have a problem with the Z axis motor Drive or the cables in between.
Once any one of the drives trip then the other axes will also be knocked off as the unit goes into E-Stop.
I would check the motor connections are all tight and the cables to the motor are not damaged.
I would also check that the Z axis is mechanically free.
Also look at the axis drive when the drive trips there will be some indication on the drive as to the fault either by a flashing light sequence or alarm display. I am not sure what motors you have fitted but photos here would help.
Re: ASRS drive
Posted: Thu 21 Feb , 2013 10:20 am
by Steve
See the following post on adding pictures to the forum.
viewtopic.php?f=17&t=823
Re: ASRS drive
Posted: Thu 21 Feb , 2013 10:48 am
There have been various drive types used on the ASRS so photos of the drive + motor + electrical cabinet will be helpful
Re: ASRS drive
Posted: Thu 21 Feb , 2013 16:14 pm
by bradders
From PM me, i have not received any answers to the LED Codes below..............
An "Asynchronous axis error" means that the ASRS drives are disabled. Open the ASRS control box and switch on the isolator and wait for the controller to power up. What is the Number / Letter on the Green 7 segment display? and what are the status LEDs on the 3 Baldor Microflex axis drives ?
Axis drive LED codes
GREEN - AC power OK, Drive enabled
RED - AC power OK, Drive not enabled, no errors
RED / GREEN (Alternating) - AC Power not present, no errors
GREEN (Flashing) - Firmware download in progress
RED (Flashing) - An error has occurred. The number of flashes (Followed by a pause) indicates which error has occurred
1 DC bus overload voltage
2 IPM (Integrated power module) trip
3 Overcurrent trip
4 Overspeed trip
5 Feedback trip
6 Motor overload (i squared t) trip
7 Overtemperature trip
8 Drive overload (it) trip
9 Following error trip
10 Error input triggered
11 Phase search error
12 All other errors, including :internal supply error, encode supply error, parameter restore failure
Re: ASRS drive
Posted: Thu 21 Feb , 2013 16:29 pm
by umair
here are some pics of our ASRS control box and the motors..
Re: ASRS drive
Posted: Thu 21 Feb , 2013 16:34 pm
by umair
we have not touched the electronics yet and need to know where to start.. no idea about the isolater switch either ...
Re: ASRS drive
Posted: Thu 21 Feb , 2013 16:35 pm
by bradders
I would get the energy chain that supports the Y axis motor and signal etc cabled repaired or you may get some broken wiring
Re: ASRS drive
Posted: Thu 21 Feb , 2013 16:50 pm
by bradders
Turning on the isolator with the door open would be a good start, that's if your health and safety regulations allow you to do so.
Re: ASRS drive
Posted: Thu 21 Feb , 2013 17:44 pm
When you power up what do the LED's on the 3 drives do? (What color & if they flash how many times?)
Re: ASRS drive
Posted: Thu 21 Feb , 2013 18:23 pm
by umair
how do i turn on the isolater, i mean whats the location of the isolator switch... and i will chk the LED response of the drives friday morning(comming day) and then will post the response here..
Re: ASRS drive
Posted: Thu 21 Feb , 2013 23:34 pm
You should be able to turn the isolator circled to the on position with the door open so you can check for errors on the drives.
Re: ASRS drive
Posted: Fri 22 Feb , 2013 6:40 am
by umair
Some times the axes motor work correctly. but after a very short time they give the following no of led blinks(red color) means error..
X axes drive= 8 led blinks (drive over load)
Y axes drive= 5 and some times 8 led blinks (feedback trip and drive overload)
z axes drive= some times 6 and some times 8.. (motor over load and drive over load)
8 blinks are most common and most seen high priority target in all axes.. (drive overload)
Re: ASRS drive
Posted: Fri 22 Feb , 2013 6:50 am
by umair
Also if possible can you please provide with any manual for the ASRS and infact for the whole Denford CIM machine. Thanks.
Re: ASRS drive
Posted: Fri 22 Feb , 2013 10:06 am
Have you viewed the help file on the ASRS software CD-ROM....ASRS.chm ?
Re: ASRS drive
Posted: Fri 22 Feb , 2013 10:15 am
Re: ASRS drive
Posted: Fri 22 Feb , 2013 10:31 am
