What is the different with QuickCAM 3D vs QuickCAM PRO?
Moderators: Steve, Mr Magoo, Martin, bradders
davidfhu
Post by davidfhu » Mon 22 Mar , 2010 3:02 am
I am a newbie for Denford Milling Machine and Software.
Currently, I am working on QuickCAM 3D. But I notice that there is an other software by the name of QuickCAM PRO. Wonder what will be the different between this two software?
Best regards,
David Fhu
“Dream as if you'll live forever, live as if you'll die today.” - James Dean
Re: What is the different with QuickCAM 3D vs QuickCAM PRO?
Post by Denford Admin » Mon 22 Mar , 2010 12:19 pm
The pro version has more "fancy" machining types available:
Raster roughing and finishing.
Also includes a raster + waterline combination plan
Waterline milling
Pencil milling
Parallel Pencil milling
Horizontal Area Clearance
Corner offset
Constant Stepover
Area Clearance
davidfhu
Post by davidfhu » Mon 05 Jul , 2010 8:35 am
Hi, Denford Admin.
Thank you for your information.
But what do all this Plans do? When do we need to make use of this Plans for our Milling in F1 D-Types and R-Types?
Best regards,
David Fhu
Post by Steve » Mon 05 Jul , 2010 9:17 am
We no longer supply QuickCAM 3D The PRO version has replaced it.
QuickCAM PRO has the same cutting stratergies as 3D plus lots of others. The other stratergies would allow you to improve the finish on a car. While the basic raster finishing is the quickest option there are contour lines left by the cutter. The other stratergies would allow you to finish areas of the model (using the custom boundary option) then add additional machining plans.
davidfhu
Post by davidfhu » Mon 05 Jul , 2010 9:20 am
Hi, Steve.
But I understand that we need to pay extra on top of the milling machine as for the QuickCAM Pro, is that right?
Best regards,
David Fhu
Post by Denford Admin » Mon 05 Jul , 2010 9:45 am
For making F1 cars, a raster plan is usually enough to get a good enough finish (before finish sanding by hand)
I would check with your F1 In Schools in-country coordinator to see if they have a special offer for QuickCAM 3D - I believe Denford have stopped supplying it, but F1 In Schools sometimes offer it free to schools when they sign up to the F1 challenge
davidfhu
Post by davidfhu » Mon 05 Jul , 2010 10:01 am
Thank you, Denford Admin.
Best regards,
David Fhu
Post by Steve » Mon 05 Jul , 2010 10:18 am
Where are you located?
With new machines we supply 2D software to allow you to make parts but QuickCAM PRO is somthing you have to purchase.
I do not think we supply the QuickCAM 3D anywhere now. It was available with F1 registration in the past as a special offer.
davidfhu
Post by davidfhu » Mon 05 Jul , 2010 10:53 am
Hi, Steve.
Thank you for your information. I will inform my users.
BTW, I am from Singapore.
Best regards,
David Fhu
