Tool change in CNC program does not stop the spindle
Post by Denford Admin » Mon 13 Feb , 2006 15:07 pm
When using more than one tool from QuickCAM 3D I find that the spindle does not stop when asking for the 2nd tool.
Post by Denford Admin » Mon 13 Feb , 2006 15:15 pm
This is a problem affecting version 1.4 QuickCAM Pro and QuickCAM 3D v3.4 - ie the current versions as of today 13th Feb 2006.
Both products had configurable post files added to let G-Code be created for any CNC machine.
The problem has appeared because the tool change section in the post file has an M05 missing.
To fix this problem until new versions are released:
Find the file Denford (Metric).ppl in
C:\Documents and Settings\All Users\Application Data\Denford\Posts
Edit the file in a text editor (eg, notepad)
Find the section [Tool Change]
and insert M5 above the line G90 M6 like this:
M5
G90 M6 T{TOOL}
M03 S{SPINDLERPM}
Post by Denford Admin » Tue 14 Feb , 2006 12:50 pm
btw you will need to turn on hidden files in order to find the post file:
in explorer goto Tools > Folder Options > View TAB - Show hidden files and folders
