Roy
- Hardware/Software: 1986 Triac modified & running Mach 3
Post
by Roy » Mon 05 Feb , 2007 20:55 pm
As i am not fully up to speed with wiring diagrams, could some one tell me on the 'IBM to TRIAC' drawing below.
What the 'loop' symbol from pin 2 on the 7 pin connector stands for.
Roy
- IBM-PNC3.JPG (69.33 KiB) Viewed 6429 times
Post
by bradders » Tue 06 Feb , 2007 8:23 am
Roy,
Its the interwoven metal screen wire that surrounds the other plastic coated cables. Therefore you want "Screened cable" to make up the final cable
Post
by Denford Admin » Tue 06 Feb , 2007 9:55 am
There was a bit of a discussion on this cable here:
viewtopic.php?t=596
Roy
Post
by Roy » Tue 06 Feb , 2007 20:23 pm
Thanks, I was thinking that possibly could be the case. But best to check with you experts!
Roy
Roy
Post
by Roy » Fri 09 Feb , 2007 18:12 pm
Hi I have got some cable which has a foil shield, will this do the job?
Roy
