old triac 24 pin connector
colinhughes
Hardware/Software: Triac
Mach3
Post by colinhughes » Fri 01 Aug , 2014 14:23 pm
HI have recently obtained a old denford triac. it has no electronics at all. I plan to run it on mach 3. there are two 24 pin plugs coming from the back of the machine (4 rows of 6 pins). I wonder if anyone Has any info on the wiring of these plugs.
Thanks....Colin
angel-tech
Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3
Re: old triac 24 pin connector
Post by angel-tech » Fri 01 Aug , 2014 15:27 pm
in the triac section there is a manual for your machine.
colinhughes
Mach3
Post by colinhughes » Fri 01 Aug , 2014 17:42 pm
Yes I've looked at that but the only 24 pin connectors in the manual are to the monitor console. The connectors on my machine are from the stepper motors and limit switches etc. So are different from the manual.
